frennings
#1 Posted : Tuesday, December 23, 2008 2:37:08 PM(UTC)
frennings
I have baled approx. 3 gallons from the bottom of the unit after the final cycle. Is there a command to activate the drain cycle only? Can you suggest a sequence to diagnose?
Thanks David
#2 Posted : Wednesday, December 24, 2008 7:51:07 PM(UTC)
Hi David,
The first thing I would check is the air gap on top of the sink, if there is one. Remove the top piece and check the air gap for a clog. If there is no air gap then disconnect the drain hose from the garbage disposer, put this end of the hose in a bucket, start the cycle and see how it drains. Any cycle begins from drain. Post the results.
Here are the break down diagrams for the Bosch dishwasher Model SHX46A05 UC/14 (FD 8211-)
You can find how to cancel any cycle and initiate the drain in the Owners Manual.
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
Bosch Dishwasher won't Drain (Dishwasher Repair)
by coachbrady 7/12/2010 6:28:40 PM(UTC)
Bosch dishwasher won't drain (Dishwasher Repair)
by Debbc 4/25/2009 8:25:42 AM(UTC)
Bosch dishwasher won't drain after installing new garbage disposal (Dishwasher Repair)
by madden611 11/25/2008 4:05:12 PM(UTC)
Bosch dishwasher won't drain, power surge problems? (Dishwasher Repair)
by vcalkins 8/16/2008 8:41:02 AM(UTC)
by downtube 7/1/2008 4:29:01 PM(UTC)
Bosch Dishwasher won't drain (Dishwasher Repair)
by Little Lost one 6/12/2008 11:30:14 AM(UTC)
by reisman 12/24/2007 7:31:35 PM(UTC)
Bosch Dishwasher Won't Drain (Dishwasher Repair)
by jshoe01 9/5/2007 5:56:15 PM(UTC)
