NICKRYAN
#1 Posted : Monday, December 22, 2008 8:45:17 AM(UTC)
NICKRYAN
:confused: Gibson dryer works great except the drum sags about 3/8 inch catching the clothes between the drum & dryer front. How can & fix this? Is it worth fixing ? Thanks. Nick
#2 Posted : Tuesday, December 23, 2008 1:52:58 AM(UTC)
Sounds like the front glides are shot
Here is your parts breakdown
Model GDE648RHS0
Check out #20 in the "frnt pnl door" section
Here is some additional info
http://www.applianceaid.com/dryers.html
I believe your unit is made by Frigidaire
kayakcrzy
#3 Posted : Tuesday, December 23, 2008 3:36:29 AM(UTC)
kayakcrzy
Actually in the breakdown of what Mr. Denman gave you, look at the #5 picture, and the small picture frame on the upper left is the rear drum bearing kit. That is what you will need. The rear bearing comes in a kit. Tom
