ppd1942
#1 Posted : Monday, December 22, 2008 2:59:18 PM(UTC)
ppd1942
Yes, I bought this stuff.
My icemaker works but only if I pull the paddle out on the bottom of the icemaker about every hour. Has anyone ever had the spring to fail (or get too weak) to push the paddle all of the way out?
jore1944
#2 Posted : Friday, December 26, 2008 11:38:34 AM(UTC)
jore1944
The return spring probably has broken (unlikely) or one or both of the ends has come out of the holes in the icemaker and paddle. Should be a very easy fix.
Remove the icemaker. The paddle is attached to the icemaker with one screw. inspect the spring to see if it is broken or one of the ends has come out. If you fine either, remove the screw and replace the spring or put the spring ends back in the holes. If the spring is broken you will probably have to improvise, as I doubt that GE will sell the spring only.
ppd1942
#3 Posted : Saturday, December 27, 2008 10:48:05 AM(UTC)
ppd1942
Thanks!!!
Just as soon as I pulled it out, I saw the spring had come loose. I put it back and now have three trays of ice in the last four hours.
