bowermj
#1 Posted : Sunday, December 21, 2008 8:03:00 PM(UTC)
bowermj
My dishwasher stops after the pots and pan cycle. It will NOT start in any other cycle, only P&P. It just stops, and the timer does not move. I can reset to P%&P and it will go through again, and stop. Any ideas?
#2 Posted : Monday, December 22, 2008 2:12:45 AM(UTC)
Here is your parts breakdown
Model DU840SWKQ0
And here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208275134.pdf
I would say that your timer is shot
If you look at the timer contacts 33 is used for Pots & Pans and 27 for Normal.
Odds are high that 27 is no longer making contact
