yvonnej2
#1 Posted : Thursday, August 25, 2011 7:54:17 AM(UTC)
yvonnej2
I have a standard length external drain hose on my Kenmore washer. Since I have moved I need a longer drain hose around 12 feet long. I found the 10 foot drain hose you have listed in the parts section. I just wanted to know would the 10 ft drain hose be able to connect to the standard one I have on my washer right now which would give me the desired 12 plus feet? And if so, can someone give me some directions and what exactly I would need to do this. Note: The hose is the ribbed espansion kind. Thanks for any help you can give me.
magician59
#2 Posted : Thursday, August 25, 2011 8:35:42 AM(UTC)
magician59
I'm not sure this will work: I would try to find a hose that will fit snugly inside the washer's drain hose and use it as a coupling between the existing drain hose and a second piece, cut off a spare. Then I would clamp it securely with hose clamps.
