Our side by side refrigerator/freezer is freezing all our food solid! Extremely cold, below 0 degrees, so cold the thermometer won't register the temperature. We already replaced the timer/defrost board last week for this problem, but it has returned.
Here is your parts break down Model KSRG25FKSS01Cannot see defrost causing - too cold Most likely cause would be your thermostat Item 5 in "Control" section |
THIS FORUM IS DEAD!!!!!!! |
