:rolleyes: My mixer will only work in high speed. What part do I need to replace?
Originally Posted by: tblackw ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) :rolleyes: My mixer will only work in high speed. What part do I need to replace? Tblack, There are 2 possibilities,based on your description, A broken Control Plate Spring Part number: AP2930085
and or a bad Motor Phase Control Assembly Part number: AP3177667
You'll have to remove the end cover plate from the back of the mixer "head" and the side trim plate screws to access the phase control and the spring, after you raise the upper housing from the lower housing by removing the screws holding the assembly together. Good Luck, :) :) :)
How do you repair these parts?
I meant replace this parts?
Any instructions?
Originally Posted by: tblackw ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I meant replace this parts?
Any instructions? The manual is not a PDF file, I can't attach it to a response. If you can send me a fax number, I'll be happy to send you the appropriate information, to assist you. :) :) :)
Originally Posted by: Joe / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The manual is not a PDF file, I can't attach it to a response.
:) :) :) Fax:706-428-8617 Need instructions on how to replacing the phase control board on my Kitchaid Mixer, Model K45SSWH.
Originally Posted by: tblackw ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Fax:706-428-8617
Need instructions on how to replacing the phase control board on my Kitchaid Mixer, Model K45SSWH. Tblack, Just faxxed the pages from the manual for you.You'll have a few extra pages. :) :) :)
Originally Posted by: Ronpaul ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) How do you repair these parts? Ron, Did you not recieve the service manual we faxxed ? :confused: :confused: :confused:
