jcutillo
#1 Posted : Sunday, August 21, 2011 10:15:07 AM(UTC)
jcutillo
My Frigidaire washer won't drain completely or spin out at all. We cleaned out the drain trap but it still won't spin.
sidfink43
#2 Posted : Monday, August 22, 2011 4:57:13 PM(UTC)
sidfink43
I am not getting your model number to come up, but assuming this is a front loader there should be tech notes inside the lower service panel which will tell you how to test some components. Start with the speed or motor control board, it is your most likely problem, but the door lock assembly and wiring to it can also be an issue.
