WDC
#1 Posted : Saturday, December 20, 2008 8:48:03 AM(UTC)
WDC
Good morning,
Dishwasher drains and fills fine. No leaks.
Bottom sprayer spins but slowly and top sprayer does not.
No clogs in sprayer or tubes and water pressure good.
I did notice pump outlet screen was torn some. See attached file. I ordered a new one.
Not sure if this is causing the problem. Is there a solenoid for the upper sprayer or does pressure control it.
Thanks for any help.
File Attachment(s):
Doc1.doc (26kb) downloaded 5 time(s).
KRS II
#2 Posted : Monday, December 22, 2008 12:58:53 PM(UTC)
KRS II
I'm having similar situation, somebody please help
WDC
#3 Posted : Tuesday, December 23, 2008 6:08:39 PM(UTC)
WDC
Hope this is helpful.
I purchasesd a new pump outlet screen. I noticed it is the identical part (checked numbers on new and old outlet) to the old one except for the following. It is flatter and less bowed.
Also I noticed there are six tiny ports which appear to be part of the motor cover. I think these are tiny water ports I did not notice it in the past. The new pump outlet screen allows them to be more apparent when installed. The old outlet screen covered it with part of the screen.
They were clogged with debris. The inner circle of the pump outlet screen sits on these holes.
After I unclogged these ports and installed the pump outlet screen my upper spinner is working. It could be these tiny ports with debris, or the new/modified pump outlet screen(old one was torn some). Also make sure you install all the pump outlet screen rubbber gaskets.
Tried to explain it the best I could.
If there is any other help you need just reply.
And yes I have a happy wife. Two weeks with no dishwasher is not good.
#4 Posted : Wednesday, December 24, 2008 1:16:35 AM(UTC)
Need model numbers to help.
