Moved into a house with A Samsung side by side Refrigerator that is less then 5 years old. One day the Freezer just went warm and the Refrigerator seems to also be warmer then usual. Had a repair man come out to look at it and he charged us $145 basically to do nothing other then move it away from the wall and unplugged it to reset the computer or circuit board in it. Called him back and he said I need a new circuit board. Was wondering if anyone is familiar with this problem and how hard it is to replace that yourself. Also where to go to order the circuit board. Thanks
Here's the breakdown Model RS2630SHThe control board is located on the back of the unit (page 9) Part Pba m Nat
Originally Posted by: libertyappl  Here's the breakdown Model RS2630SHThe control board is located on the back of the unit (page 9) Part Pba m Nat I have a Samsung rs267lash which I believe also has a problem with the pba board.Is it also in the back of the fridge and do you mean inside or outside the refrigerator? I am having a hard time finding it.Thanks.
There is a small panel on the back of the unit the pcb is behind that./
Nat
Crika,
Did you ever get the RS267LASH fixed. I have one also that I am working on with the same issue.
