FRIG
#1 Posted : 17 years ago
FRIG
MFG NO -- P7680807WL
SERIAL NO -- 8603091131
Never shuts off--frig temp=39 degrees freezer temp= 18 degrees
settings for frig & freezer are on the lowest setting (1)
#2 Posted : 17 years ago
All the fans running, no condenser clog. Any frost in the freezer?
If ok, pull freezer back panel and describe frost pattern.
FRIG
#3 Posted : 17 years ago
FRIG
All Fans Running
No Condenser Clog
No Frost In Freezer
Removed Back Freezer Panel--no Frost
#4 Posted : 17 years ago
You have serious refrigeration problems.Bad refrigerant leak,bad compressor, or clogged capillary. Hard to tell without looking at it. Repair cost is really high, between $400 and $600 Probably new fridge time, just not worth spending this kind of money.
my Frigidaire refrigerator runs continously (Refrigerator & Freezer Repair)
by obrien1934@aol.com 9 years ago
