ron carmody
#1 Posted : Friday, December 19, 2008 9:22:28 AM(UTC)
ron carmody
My icemaker will not make ice. We've replaced the filter, the sellunoid and determined that the circuit boards are okay. The LED lights are working correctly/blinking sequence etc. The water tube to the ice maker is not frozen and we can still get water from the water dispenser on the door of the freezer. The freezer temp is 9degrees. We have not checked the 120VAC issue nor used a jumper on the t7h points; however, not sure we know how. We filled the ice tray with water manually and it is frozen solid; however, the ice maker has not "dumped" the ice.
At this point in time, there is no water being "called" to the ice-maker. Is there anything else we can do to "make that happen"?
We've not checked the "thermostat" (not sure we know how). Does this sound like a thermostat problem? (Though I'm not sure how that would affect the water not filling the tray!!)
Any advise???
Thank you,
Ron Carmody
libertyappl
#2 Posted : Friday, December 19, 2008 10:17:54 AM(UTC)
libertyappl
Sounds more like the ice maker module issue.
Nat
ron carmody
#3 Posted : Friday, December 19, 2008 10:33:25 AM(UTC)
ron carmody
ie.....we need a new icemaker!!....we are Missourians as well!! relocated to Texas!!
libertyappl
#4 Posted : Friday, December 19, 2008 12:54:47 PM(UTC)
libertyappl
A new IM isn't much more expensive than a module itself.
Bet it's a little warmer there than it is here....lol.
When I was a kid I lived in Wichita Falls for a while and Baycliff for a summer, other than that I've lived in MO all my life ;)
Na
