I need to replace the feed line for the water dispenser. Do I need to remove the door? How does the front bezel panel get removed (from the outside or once the door is off?
www3.sears.com
Try this link and input your model number, there's diagrams of the dispenser and freezer door that may help you determine how to make the tubing replacement... My experience has shown the water reservoir will need a thorough cleaning or replacement as well... cheers, kooler
