boydcage
#1 Posted : Tuesday, July 19, 2011 9:41:04 AM(UTC)
boydcage
Every expert I've talked to assures me the allen wrench solution is the way to go in general garbage disposal troubleshooting. BUT... I have looked up & down on this unit and have yet to find the "female" slot for the wrench.. just a smooth round bottom plate with a tiny screw head in the middle. I found the red re-set button (on the side- didn't help the issue) and I'm not the original owner, & bought my own allen wrench. Does anyone know if this is the super rare case where the wrench solution is not applicable? Or other solutions?
Joseph7820
#2 Posted : Friday, August 19, 2011 3:36:16 PM(UTC)
Joseph7820
GE Garbage Disposals do not use the "Allen Wrench" system.
The "Allen Wrench" system is used by In-Sink-Erator Garbage Disposals. The allen wrench is used to tighten and loosen the disposal unit to the sink flange.
The allen wrench is also put into a slot in the bottom of the In-Sink-Erator unit to turn it in order to help free any jams.
