My KicthenAid dish washer model KUD124SE will not fill up with water.It will go through all the cycles but does not fill with water? Is it the float or perhaps a blockage in line inlet on the dish washer? The float seems to be in down position.
Originally Posted by: Bill LeVey  My KicthenAid dish washer model KUD124SE will not fill up with water.It will go through all the cycles but does not fill with water? Is it the float or perhaps a blockage in line inlet on the dish washer? The float seems to be in down position. Bill, You're on the right track, Yes, you should check the float for free up and down movement , and listen for the water level switch to "click". If that checks good, replace the fill valve, Part number: AP2921090
Good Luck, :) :) :)
thank you for info,now I have a leak at bottom of the tub at motor and looks like the tub seal is leaking.I can not get the mounting screw on impeller off which is inside of the tub.Is there a trick to getting it off?Need to dismantle it all it all to get to the tub seal and pump seals ubder neath.Please help me.
Originally Posted by: Bill LeVey  thank you for info,now I have a leak at bottom of the tub at motor and looks like the tub seal is leaking.I can not get the mounting screw on impeller off which is inside of the tub.Is there a trick to getting it off?Need to dismantle it all it all to get to the tub seal and pump seals ubder neath.Please help me. Bill, You'll find it a bit easier to remove the pump assembly and work on it outside the dishwasher. *** Remove power to the dishwasher *** 1. Remove the front access panel. 2. Disconnect the wiring harness connector from the pump motor. 3. Disconnect the two wires from the operating thermostat mounted on the pump housing. 4. Diconnect the drain hose from theconnector on the pump by squeezing the hose clamp with a pair of pliers. 5. Unscrew the tuned sound absorber shaft from the motor housing. 6. turn the four pump mounting supports approximately 90 dgrs. From inside the cabinet, 7. Remove the lower dishrack and lift the pump and motor assembly from the unit. Removing the vertical water tube 1. Remove the upper dish rack. 2. Dislodge the upper portion of the vertical water tube from the plastic knob on the back of the tube by pressing down on the nozzle. 3. Rotate the lower end of the tube either left or right off the pump nozzle. NOTE: Do not pull the vertical water tube forward or up in an attempt to remove it from the pump nozzle. This will damage the "O" ring seal in the tube opening. You'll find it easier to dismantle the pump components, just don't loose any of the interior parts and components. :) :) :)
