I have a Kenmore Oasis washer that is showing F51 error code. I googled the problem and it said that it was prob a control board malfunction. I ordered and replaced the control board and are still having the same error message coming up. Please help with suggestions.:confused:
I think you got the wrong interpretation of the code. There is a motor rotor position sensor on this model and the error code refers to it, or the rotor.
There is a tech sheet under the top which will tell you how to test for the problem.
This is a very complex machine, and if you want to fix it yourself be prepared to dive deeply into it.
