2 Pages<12
smauldin
#11 Posted : Thursday, August 18, 2011 1:07:19 PM(UTC)
smauldin
Wiley,
It is a good idea to have him to check the pressure in the system.
Gene, any suggestions on my issue? It's similar, but not exactly the same.
Thanks.
#12 Posted : Saturday, August 20, 2011 3:16:10 PM(UTC)
Thanks.
Run the Service Diagnostics Mode and post the results. The Tech sheet with the instructions is attached.
Handles attachments
wiley46
#13 Posted : Saturday, August 20, 2011 5:15:09 PM(UTC)
wiley46
Tech came back today, once again the coils were iced up, not letting air flow across them and up into fridge compartment (freezer temp fine, fridge in high 40s).
Diagnostic step 07 gave an 02 Code (Defrost Heater energized) which he said indicated that a thermostat (bi-metal) that controls the heater was bad...so he replaced it. We'll see....
2 Pages<12
