I have a GE Triton dish washer model #gsd55560g00ss. When you select a normal cycle the machine starts and runs fine for about ten minutes. You can hear it add water, wash, and drain water. It will then just stop, the drying light will start blinking accompanied by a beep. This will go on until you push the reset button. I turned off the circuit breaker for about ten minutes. I have tried several cycles all ending with the same result. Any ideas?
No one has ever seen this or something similar? Looks like time to replace it.
Did you ever find a solution for this? I just encountered the same problem.
