lennyk
#1 Posted : Thursday, December 18, 2008 11:25:31 AM(UTC)
lennyk
I have a whirlpool quiet partner iii which appears to be brain dead,
it does not respond to the diag sequence on the keypad
is it safe to say that the control board is dead or
should I still go ahead and check other electricals ?
libertyappl
#2 Posted : Thursday, December 18, 2008 12:51:40 PM(UTC)
libertyappl
If the keypad doesn't respond it could be the keypad or the control board. They are separate parts on most models. Post your model number for the best info.
Nat
lennyk
#3 Posted : Friday, December 19, 2008 4:42:27 PM(UTC)
lennyk
the control board was changed and it works again
any idea what causes a control board to go bad ?
could it be voltage spike ?
libertyappl
#4 Posted : Saturday, December 20, 2008 9:54:22 AM(UTC)
libertyappl
Voltage spikes are a common issue with any control boards.
Nat
