rkmcprez
#1 Posted : Wednesday, August 17, 2011 8:08:36 AM(UTC)
rkmcprez
Hello, I'm replacing a tub liner collar, Liner - Tub Part Number: AP4024726 on a Maytag LAT2500AEE. Does this part require grease when assembling? Thank you.
magician59
#2 Posted : Wednesday, August 17, 2011 8:47:47 AM(UTC)
magician59
It does not require grease. It does require a clean transmission shaft, however. Don't overdo it, though. it should slip onto the shaft and be able to turn without freezing up. It shouldn't spin more than about a half turn if you give it a flip.
rkmcprez
#3 Posted : Wednesday, August 17, 2011 10:16:25 AM(UTC)
rkmcprez
Thank you very much, Magian59, that helps alot. I appreciate it!
