superdav
#1 Posted : Tuesday, December 16, 2008 8:13:18 PM(UTC)
superdav
I have a GE gas range (model #JGBS21HED3ww). Just replaced the thermostat, the oven will not turn on when selected. The thermostat appears to work, and the ignitor/glow plug works perfectly, no gas is being supplied to the lower unit.
Now the curious part, when I turn on the back burners after a couple of minutes the oven starts to get gas and kicks on, then operates normally.
Do I have a faulty regulator? Any help would be appreciated.
kayakcrzy
#2 Posted : Thursday, December 18, 2008 5:29:11 AM(UTC)
kayakcrzy
Replace the ignitor. The ignitor is not strong enough to open the gas valve. Once you replace it, it will work fine. Tom ApplianceEducator.com
no gas to oven burner (Oven Repair (including Ranges and Cooktops))
by Dixie Air 4/4/2010 12:36:42 PM(UTC)
ignitor glows bright orange but no gas to oven, broiler works fine (Oven Repair (including Ranges and Cooktops))
by browndeer 8/2/2009 8:07:02 PM(UTC)
Whirlpool Gas Range - no gas to oven (Oven Repair (including Ranges and Cooktops))
by TCPerch 7/2/2009 1:18:35 PM(UTC)
No gas to oven (Oven Repair (including Ranges and Cooktops))
by michalakes 11/6/2008 3:24:34 PM(UTC)
