You have been a member since:: 8/16/2011(UTC) Views messages in topic : 2
The "Time Cook" button on my microwave doesn't work anymore, all of the other buttons work and we're still able to use the microwave by using the "30 second" button. I was thinking of fixing the problem by replacing the Control Panel Assembly, part# WB07X10626. I found the part (#120) on the GE parts diagram: https://genet.geappliances.com/I...0048500/00048520.p01.pdfCould anyone give me their opinion on whether this would fix my issue? Is it as simple as I think it is? 1. Remove the griddle, 2. unscrew the panel screw, slide it up and out, 3. unplug it 4. swap it out with the new control panel I don't want to do anything stupid.
