myed
#1 Posted : Monday, August 15, 2011 1:52:34 PM(UTC)
myed
maytag washer makes a high pitch squeling noise when in washing mode and during first part of spin out washes and spins out fine i have replaced the bearing at the bottom of big pulley and both belts sounds like its coming from the pump but its plastic and i wouldnt think it would make that kind of noise any help would be appricated
sidfink43
#2 Posted : Wednesday, August 17, 2011 12:45:17 PM(UTC)
sidfink43
Yes, given that it happens in agitation and spin the pump is a very likely source of the problem. It can make that noise even though a lot of it is plastic. There may even be something caught in it.
