doitmayself
#1 Posted : Monday, August 15, 2011 11:31:09 AM(UTC)
doitmayself
i have a combo washer and dyer that after the spin cycle is finished my clothes are quite wet but no water is left in the tub. what might be my problem?
sidfink43
#2 Posted : Wednesday, August 17, 2011 12:35:20 PM(UTC)
sidfink43
If it is spinning at the correct speed,then you probably have a clogged drain hose, probably leading from the tub to the pump.
KENMORE 80 series wet clothes after spin cycle (Washer Repair)
by APPLIANCEDUDE1972 4/22/2015 4:05:46 PM(UTC)
