Aloha, I can not figure out how to remove the faceplate off of this Kenmore. Gene said in a few earlier posts "Whirlpool" that you stick a flathead screwdriver on the lower part of the face plate and it should snap right off. Problem is that is what I am affraid of. You know snapping right off! Well as I was looking at the schematics of this faceplate it seems as though it has to up and pop out at the top. The problem that I am having is that the Ice Chute door doesn't close all the way or if it does then the ice gets blocked and will not come out. Each time we use it we have to manually fidget around with it. If we don't then the Ice builds up and when the ice builds up I cannot get rest because of all the complaining and bellyaching I get from my wife. HELP!!!
