I see, that explains quite a bit. Ok, I will position those fingers to be pointing to the left wall of the freezer and see what she does. Hopefully that'll do the trick. Fingers crossed. Thanks a lot, abadfish, I really appreciate it! Great help! :)
Ok, I have encountered another problem. The fingers will only point to the right or straight down. It will not turn any farther than those 90 degrees. Broken or wrong part maybe?
Anybody? Help, please. :)
Guess it's time to call the repairman...Thanks anyway
