I noticed my GE Nautilus was not draining at the end of the last cycle...I pulled it out and noticed the small porpeller ( or impeller) was off and laying in the bottom of the rubber elbow/ valve whatever it's called... the screw that held the impeller in place was gone and the threads on the rod where worn or damaged....I did notice that the rod that turns the impeller still worked the question is Do I need to purchase and install a pump seal and impeller kit or just the small impeller from the kit or what should I do???
:confused:
What did you end up doing? I was thinking about just buying a new dishwasher...
