My bottom element will not come on. Hopefully someone can help me out with this? : )
Thx,
Colin
Hi Colin,
The model number you posted does not come up. Is it American model?
Hmmmmmm...... I'm in Canada.... Oven was here when i bought this place..... prob over 10 years old... That was all the info i could find, besides the serial #. I will have another look...
Unplug the unit Usually one or two screws and the element should pull forward. On some units you may have to remove the back plate from the stove. Disconnect the wires from the element and check it with a meter. Should be approximately 10 ohms.
If OK you have a control problem.
MABE is the major parts supplier for GE in Canada |
THIS FORUM IS DEAD!!!!!!! |
