cabin1951
#1 Posted : Tuesday, December 16, 2008 4:40:05 AM(UTC)
cabin1951
how do you troubleshoo the deftost timer and thermocouple? is there a easy way to check the whole defrost cycle?
abadfish66
#2 Posted : Tuesday, December 16, 2008 6:42:11 AM(UTC)
abadfish66
If you post your model# I can help
cabin1951
#3 Posted : Tuesday, December 16, 2008 7:55:31 AM(UTC)
cabin1951
i don't have the model on hand right now, i am at work but it is probably about a 8 or 9 year old side by side ge .
abadfish66
#4 Posted : Tuesday, December 16, 2008 8:02:44 AM(UTC)
abadfish66
ok, post it when you get it, Is it a SxS, and where are the control knobs for the temperature, and what is the probblem with it?
cabin1951
#5 Posted : Tuesday, December 16, 2008 8:37:50 AM(UTC)
cabin1951
the control knobs are in the refrig section top rear, is that where the timer is located.
abadfish66
#6 Posted : Tuesday, December 16, 2008 8:46:03 AM(UTC)
abadfish66
Yes, if it's the fridge I'm thinking of, remove the knobs, then remove the shield and it's on the right.
cabin1951
#7 Posted : Tuesday, December 16, 2008 8:57:25 AM(UTC)
cabin1951
so is there a easy way to check it? it is a ge refrig. i don't remember if i mentioned that, and if i unplug and let it defrost for a couple of days it works for about 2 weeks. also is the heater the most common problem when refrig. doesn't defrost?
abadfish66
#8 Posted : Tuesday, December 16, 2008 9:00:57 AM(UTC)
abadfish66
Most likely problem is the heater, remove the back panel of the freezer section, and visually look at the heater, if the glass tube is black, replace the heater.
cabin1951
#9 Posted : Tuesday, December 16, 2008 9:02:54 AM(UTC)
cabin1951
Thank You, About How Much Should I Expect To Pay For A New Heater?
abadfish66
#10 Posted : Tuesday, December 16, 2008 9:07:08 AM(UTC)
abadfish66
Around $50.00
Guest (4)
