washing momma blues
#1 Posted : Sunday, December 14, 2008 7:02:37 AM(UTC)
washing momma blues
My white westubghouse will fill then you hear a click then all it does is hum. After what is supposed to be the washcycle then it sounds like it spins out then rinse fill then it sounds like it spins out again. When you lift the lib to see what is done and the autolock from the lib will let you open there is no water and the clothes are still a little wet not so much on the top but as you go down futher the wetter they get. Can you help a women on her own trying to fix it. Thank you. washing momma blues:confused:
#2 Posted : Monday, December 15, 2008 4:08:35 PM(UTC)
If you know how to use a simple tools then you probably can do it.
Remove the front panel and check the belt. Remove the belt and run the washer to see if the motor works. Post the results.
