ThomasN
#1 Posted : Thursday, June 10, 2010 8:08:28 AM(UTC)
ThomasN
We have a Whirlpool Accubake gas range. The cooktop works, yet the bake & broil do not. Bake clicks twice, broil may click once. (not always) We smell no gas fumes, and cannot hear gas flowing. All connections are correct, in place. I hold the off button down to get an error code, none displayed. I also did some research online and heard three stories with varied parts replaced, all successful. I have put the OHM meter on the varied wires, and get no readings. No voltage on igniter leads, no reading at the Valve/Register How can I diagnose or narrow down the problem? I cannot afford to throw parts at it...Valve/Register is $141, Control Panel is $111, DSI is $162. That is $414... New is $475, less headache. :confused:
jerrypigsty
#2 Posted : Tuesday, August 9, 2011 1:38:42 PM(UTC)
jerrypigsty
i have a whirlpool sf 367lek oven and the problem im having is that the pilot light wont light and i smell gas
Oven & broiler will not light (Oven Repair (including Ranges and Cooktops))
by C Dale 7/13/2011 4:55:34 PM(UTC)
