CAN I DO IT
#1 Posted : Friday, July 27, 2007 3:03:57 PM(UTC)
CAN I DO IT
If I Can't Move The Agitator By Hand, What Causes This? This Is The Same Washer That Agitates Just Fine, But When Advances To Spin/drain Cycle It Stops And There's No Sound At All. It Does This On All Cycles(reg., Perma-a-press, Gentle). Any Info. Will Be Much Appreciated!
ApplianceJunk
#2 Posted : Friday, July 27, 2007 8:12:26 PM(UTC)
ApplianceJunk
You may not be able to turn the bottom of the agitator by hand.
If the washer does not make a sound during pump out or spin then it's time to check the washer lid switch.
