markmcn
#1 Posted : Monday, August 8, 2011 9:01:30 AM(UTC)
markmcn
My dishwaher is leaking from underneath around what appears to be the pump houseing. I have checked online and there is a gasket in there. Do these go bad often if they are not used? This unit is in a rental and was not use much last year at all.
jz77comcast
#2 Posted : Monday, August 8, 2011 1:12:51 PM(UTC)
jz77comcast
gaskets can crack when old. its a time thing not necessarily a usage thing. Mine leaks after >10 years.
