Hi
Due to a water leak in my F&P washer the module board had to be replaced.
I resistance tested the parts as per replacement instructions with all ok.
After installing and switching on, the module beeps but i get no LEDs and the display panel doesn't respond when pressing the buttons.
Any idea what is at fault here?
I'm guessing maybe the display was damaged when the module got covered in water and shorted out but want to be sure before running down the part.
I don't think any of us have enough experience on the P-K models to offer any advice. Try to find a Forum where there are some experienced P-K folks.
Sorry, good luck.
