gtkeith
#1 Posted : Sunday, December 14, 2008 6:04:18 AM(UTC)
gtkeith
Whirlpool washing machine discharge water smells very bad and clothes always have mold smell. Serviceman came over and cleaned out a filter on the bottom of the washer and that didn't help, I run the bleach through it and also use the AFFRESH nothing seems to help. It smell so bad I have to close the door to the laundry room and open the window.
#2 Posted : Monday, December 15, 2008 1:59:16 PM(UTC)
How many times did you use Affresh? If there is a such heavy smell then one or two times maybe not enough. Also keep the washer door ajar when it's not in use for better ventilation.
gtkeith
#3 Posted : Monday, December 15, 2008 2:38:28 PM(UTC)
gtkeith
Several times and also did the bleach and we leave the door open all the time
libertyappl
#4 Posted : Monday, December 15, 2008 2:51:37 PM(UTC)
libertyappl
Just another thought, make sure your drain hose isn't down in the drain pipe too far. It can cause a siphon effect pulling some of the dirty water back inside the pump.
Nat
#5 Posted : Monday, December 15, 2008 4:31:43 PM(UTC)
Do not know if you have this but here is a tech sheet with a bit of info on cleaning the door seal
https://www.servicematters.com/d...0Sheet%20-%208182677.pdf
