hondakubota
#1 Posted : Wednesday, August 3, 2011 3:58:00 PM(UTC)
hondakubota
Washer will not drain can someone walk me through a fix?
sidfink43
#2 Posted : Friday, August 5, 2011 5:19:54 PM(UTC)
sidfink43
Clean out the pump and internal drain hoses, that should do it as these machines get all sorts of things from your pockets in the hoses and drain.
If that does not fix it your pump may be defective.
hondakubota
#3 Posted : Friday, August 5, 2011 6:07:11 PM(UTC)
hondakubota
Sounds great can you give me some insight on how to do this? Back panel? From bottom? Top? Which hose? Etc. Thanks!
LG washer wont drain (Washer Repair)
by Sunshine56 11/14/2012 6:36:13 AM(UTC)
My LG washer wont drain (Washer Repair)
by punks1977 11/9/2008 11:08:16 AM(UTC)
