jackwolfe
#1 Posted : Friday, August 5, 2011 11:52:50 AM(UTC)
jackwolfe
Replaced the the controal board unit completed one wash cycle now the clean light stays on and unit dose not function checked all of the thermostats ohm meter and the show 0 on the read out. any suggestions?
Joe / APP Team
#2 Posted : Friday, August 5, 2011 1:36:32 PM(UTC)
Joe / APP Team
Jack,
A couple of questions first:
Does "0" on your meter indicate a "closed" circuit, or open circuit ?
All the thermostats should have closed circuits at room temperature, and the heater element should have a 10 to 30 ohm resistance reading on your meter.
You do mean the "Clean" LED light is "flashing" basically 7 pulses then a pause ? That indicates the water temperature did not reach the prescribed temperature. You will want to check and make sure the water temperature in the bottom of the tub on the first fill is 120 to 130 dgrs F. after you re check the element and thermostats.
You'll need to run the diagnostic cycle in order to reset the control assembly :
DIAGNOSTICS CYCLES AND RAPID ADVANCE SERVICE FEATURE
Pressing the following option keys in the sequence shown will either start the Diagnostics Cycle or turn on the Rapid Advance feature for stepping through customer selectable cycles:
HIGH TEMP SCRUB
(POWER SCOUR)
(HIGH TEMP SCOUR)
AIR DRY
(NO HEAT DRY)
(ENERGY SAVER DRY)
HIGH TEMP SCRUB
(POWER SCOUR)
(HIGH TEMP SCOUR)
AIR DRY
(NO HEAT DRY)
(ENERGY SAVER DRY)
If the above key sequence is entered with the dishwasher in Standby, the Diagnostics
Cycle is started. The Diagnostics Cycle can be rapid-advanced, interval by interval, by
pressing the Pots&Pans/Heavy or Anti-Bacteria/Cookware cycle key.
Good Luck,
