aj44
#1 Posted : Thursday, August 4, 2011 6:16:02 PM(UTC)
aj44
daycor double oven making loud beeping noise?
#2 Posted : Friday, August 5, 2011 4:40:31 AM(UTC)
A model number may help others help you.
Though I doubt any tech info will be available for this unit it is still worth a try.
Try removing power from the unit for 5 or so minutes, either unplug it or flip the breaker off.
It may reset itself.
Is there an error code on the display?
