My GE frig has water to the door but ice maker isn't getting water. I assume there are separate outlets for the door and the ice maker. If so then is there a filter or screen that could be clogged or is the water valve toast? Water valve number is WR57X10051
What kind of ice maker is in your fridge: an electronic with the green LED or an electromechanical with the arm on side? If it's an electronic and the LED is blinking then the ice maker is bad and has to replaced. Check the water feeding tube into the ice maker for frost built up inside. If there is nothing wrong and it's an electromechanical ice maker then force the ice maker into harvest by pulling the ejector blades. At the end of the second revolution the ice maker should fill up with water. If it did not then remove the wires from the ice maker solenoid on the water inlet valve (the blue one with the 1/4" water outlet) and check this solenoid for continuity and for 120VAC to it while the ice maker calls for water. Post the results. Here are the break down diagrams for the GE refrigerator Model TFX22ZRXDWWGene.
