tina duncan
#1 Posted : Friday, December 12, 2008 7:36:02 AM(UTC)
tina duncan
this dish washer works fine for it's age. The blower was noisy so I took it out to see if I could fix it. The squirrel cage was hitting the bolts behind it. I fixed that and now can't remember which wire plugs where. Searched maytag site and user's guide , can't find a wiring schematic. blower part has motor - 2 wire mounts, relay -3 wire mounts. Have red yellow purple and 2 double white wires.
libertyappl
#2 Posted : Friday, December 12, 2008 7:39:43 AM(UTC)
libertyappl
Your wire schematic should be inside the control panel or attached to the kick plate of your dishwasher.
If not I will try to locate one from the tech site for you.
Nat
tina duncan
#3 Posted : Friday, December 12, 2008 7:42:36 AM(UTC)
tina duncan
thanks, the kick plate was missing when we got it.
libertyappl
#4 Posted : Friday, December 12, 2008 7:47:13 AM(UTC)
libertyappl
Supposed to be inside the control panel. According to the service manual.
Nat
#5 Posted : Friday, December 12, 2008 7:04:54 PM(UTC)
Here is a service manual, I believe your unit's wiring is 4-9
http://www.servicematters.com/m...ibrary/docs/16007823.pdf
tina duncan
#6 Posted : Saturday, December 13, 2008 7:23:16 PM(UTC)
tina duncan
Perfect! that technical information was exactly what I was hunting for! Thanks for you time and assistance.
Dryer Timer Wiring Schematics (Dryer Repair)
by DVO1978 12/13/2013 11:31:20 AM(UTC)
Wiring Schematics (Washer Repair)
by steveo0707 12/7/2013 1:54:07 PM(UTC)
Wiring Schematics (Dishwasher Repair)
by maiteajoe 6/27/2011 5:57:42 AM(UTC)
