mattwithcats
#1 Posted : Wednesday, December 10, 2008 11:08:07 AM(UTC)
mattwithcats
Whirlpool dishwasher stuck in rinse. Water heating light is on. Water is hot, but dishwasher continues to run. Cycle completes in low energy / China, but on Normal or higher does not drain / advance.
I think it is either the hi limit or the operating thermostat.
Can you tell me which?
Hi limit is AP3010530,
Operating / Cycling is AP3115144
Thanks,
#2 Posted : Thursday, December 11, 2008 1:14:40 PM(UTC)
The first failure suspect is the cycling thermostat AP3115144. The hi-limit thermostat is a safety device to prevent overheating.
Here are the break down diagrams for the whirlpool dishwasher Model DU920PFGB0
#3 Posted : Thursday, December 11, 2008 1:41:44 PM(UTC)
And here is the tech sheet and wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208066008.pdf
https://www.servicematters.com/d...0Sheet%20-%203379193.pdf
Buy a meter otherwise you are guessing and so am I.
You can get a decent digital multimeter for under $20.00, you do not need fancy though it is nice if the leads are a couple feet long.
You can then check the heater for resistance (usually around 25 ohms) and the thermostats (should be 0 ohms at room temperature).
There is a good sticky on meter usage at the start of this forum
Maybe it is heating but the unit does not sense the temperature increase.
