vbirkenthal
#1 Posted : Thursday, July 28, 2011 1:37:52 PM(UTC)
vbirkenthal
I need to know how to install a new door since my old one has stains that won't come out because of the steam in the machine. I anyone could let me know what I need to do to replace it I would appreciate it. I have ordered the replacement door and it is on its way. Thanks!
#2 Posted : Thursday, July 28, 2011 2:36:25 PM(UTC)
Which part of the door, inner or outer, did you order?
Here are the breakdown diagrams and Replacement parts for Bosch SHX46A06 UC/14 (FD 8211-) | AppliancePartsPros.com
vbirkenthal
#3 Posted : Saturday, July 30, 2011 12:49:13 PM(UTC)
vbirkenthal
I ordered the outer door the old door has water like stains on in that will not come off so I am trying to replace the black outer cover since the dishwasher works great just looks bad. Thanks Vickie,
vbirkenthal
#4 Posted : Saturday, July 30, 2011 12:51:04 PM(UTC)
vbirkenthal
Outer thanks for your future help.
Vickie
#5 Posted : Saturday, July 30, 2011 1:48:58 PM(UTC)
Vickie,
Open the door. Holding the outer door from the under the door, remove the six T-20 Torx screws located three on each side of the inner door and two screws (#2 on the diagram).
Remove the outer door panel.
Remove the two screws secured the door handle and, using the same screws, install the door handle on the new outer door panel.
vbirkenthal
#6 Posted : Saturday, July 30, 2011 6:35:45 PM(UTC)
vbirkenthal
Great response times and really easy to follow instructions! Thanks again.
Vickie:):):)
#7 Posted : Monday, August 1, 2011 12:00:30 PM(UTC)
You are welcome Vickie. Keep us posted.
