Jim Gaspar
#1 Posted : Saturday, July 30, 2011 11:52:00 AM(UTC)
Jim Gaspar
Our washer is making a loud whir during spin cycle only and the motor is overheating and shutting down. However, I put a cooling fan on the motor and was able to run a load, and the both the upper and lower bearings stayed very cool to touch after the spin cycles.
Is this probalby a motor bearing problem, or is more troubleshooting necessary? The motor appears easy to replace but anything else might be a show stopper for something so old (the SS bucket is still good etc).
Thanks in advance.
sidfink43
#2 Posted : Monday, August 1, 2011 5:10:47 PM(UTC)
sidfink43
I think something is hanging up in the transmission area, and given the age of the machine I think you should replace it. If the motor were the problem you would be having trouble in agitation, so that easy fix is not available.
Guest (4)
