andypo
#1 Posted : Thursday, December 11, 2008 11:33:04 AM(UTC)
andypo
Ignighters work well. Takes up to 5 minutes for gas to start flowing (have trued with all burners) Once one burner lights gas flows quickly to light others. IS this a regulator issue or is there a safety valve that needs replaced?
#2 Posted : Friday, December 12, 2008 11:48:01 AM(UTC)
Most likely the problem is a bad gas pressure regulator.
- The part number for the gas pressure regulator is AP4346295
Here are the break down diagrams for the GE stove Model JGP328BEC1BB
GE Profile cooktop delayed gas flow (Oven Repair (including Ranges and Cooktops))
by hhrowal 12/11/2012 9:48:48 AM(UTC)
