servethelamb
#1 Posted : Thursday, December 11, 2008 10:35:53 AM(UTC)
servethelamb
Hi all,
I am having a problem with the spin cycle on this washer. It goes into an unbalance at about the 6 min. mark, but not everytime. I have checked the suspension rods and the hubs under the washplate and all appear to be ok. When i tipped it to check the bottom it appeared to still have some water in the outer tub (it doesnt sound like a lot). Could the problem be weak springs or maybe the secondary water pump. Is this pump supposed to pump the water back into the tub while in the spin cycle? I am stumped why it is doing this. It worked fine for three years and then until this.
Thanks for the help
Drags1998
#2 Posted : Thursday, December 11, 2008 11:22:53 AM(UTC)
Drags1998
The water you heard sloshing around is in the balance ring for the tub, The noise you heard is NORMAL!!!! Mane sure that the wachine is on a SOLID FLOOR!!! and the rear legs are extended!!!:)
servethelamb
#3 Posted : Thursday, December 11, 2008 11:32:10 AM(UTC)
servethelamb
It is on concrete and leveled perfectly.
Guest (4)
