Dishwasher will not turn on. replace circuit outlet. but dishwasher does not respond. What can I do next? Or what part do I have to replaced?
Originally Posted by: froggy0406  Dishwasher will not turn on. replace circuit outlet. but dishwasher does not respond. What can I do next? Or what part do I have to replaced? Froggy, First you need to remove the lower kickplate panel, remove the junction box cover and check the voltage supply and diswasher wire harness connections, for tight proper connections. Then dismantle the contorl panel from the door assembly and check the thermal fuse for damage or loose connetions as well Part number: AP4423189
Based on your post, thats where you'd want to start. :) :) :)
