rifraf2001
#1 Posted : Friday, July 29, 2011 11:21:53 AM(UTC)
rifraf2001
This Kemore Ultra Fills with water just fine the water is hot then goes into the wash cycle and immediately pumps out all the water. What is the most likely cause of this? Thanks in advance.
paul martin
#2 Posted : Wednesday, October 12, 2011 7:32:09 PM(UTC)
paul martin
I have same problem. After looking at wiring dia. since there is no separate drain valve to malfunction it looks to be the timer.Must be that the drain terminal on timer is energized during wash cycle.I will check that tomorrow and let you know if thats it.
Paul
rifraf2001
#3 Posted : Wednesday, October 12, 2011 8:31:40 PM(UTC)
rifraf2001
Thx. Larry
Guest (4)
