Medamida
#1 Posted : Thursday, December 11, 2008 6:06:43 AM(UTC)
Medamida
Yesterday I ran 3 loads through the dryer but when I went to do the 4th the dryer was completely dead. The timer, which would usually continue to click if I took a load out early, is not making a sound. I have checked out the door latch, the vent for clogged lint and unplugged and plugged it in again. Next up I am going to replace the fuses but I don' think that is the issue, then again I ahve never replaced those fuses in 14 years so maybe.
Thank you for any insight.
M
libertyappl
#2 Posted : Thursday, December 11, 2008 8:37:04 AM(UTC)
libertyappl
I believe this is the part you will need Part Details - WHIRLPOOL Thermal fuse (disposable, one time fuse), part number: 3392519
Remove the rear panel to access it.
Nat
