3 Pages<123
pmase123
#21 Posted : Thursday, July 28, 2011 10:39:52 AM(UTC)
pmase123
ok so i found it .. it was at the top of the freezer. wow. and the heater at bottom. so to test the thermostat i put wires together and tak a oms reader to it ... ? correct? and that will tell me if that is bad or heater. so i looked at teh timer and the plug part looks good in color the prongs are copper color with a little discoloration ..
#22 Posted : Friday, July 29, 2011 12:43:12 AM(UTC)
[COLOR="DarkRed"]so to test the thermostat i put wires together and tak a oms reader to it ... ? correct? and that will tell me if that is bad or heater.[/COLOR]
No you do not put the wires together.
You keep them apart and then you put a meter lead on each wire to measure the parts resistance.
Then you are measuring through the one wire and through the part and back through the other wired.
The defrost thermostat should read 0 ohms (closed) when it is frozen.
Note: It opens (infinite ohms) just above freezing.
The defrost heater should read approximately 20 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
3 Pages<123
