imhotep
#1 Posted : Thursday, July 28, 2011 10:00:57 AM(UTC)
imhotep
Sorry the model # is actually
#FEF326AQG
After a power outage our stove and range will not heat. The digital display comes on and responds to buttons, but no heat on the electric burners or inside the oven.
Is this a safety mode that I need to exit out of somehow?
Or is it more likely something got fried by a power surge?
#2 Posted : Friday, July 29, 2011 4:35:15 AM(UTC)
Here is a wiring diagram
http://manuals.frigidaire.com/p...pringfield/316255302.pdf
[COLOR="DarkRed"]
Is this a safety mode that I need to exit out of somehow?[/COLOR]
Not that I know of.
[COLOR="DarkRed"]Or is it more likely something got fried by a power surge?[/COLOR]
As you can see from the wiring diagram the stove top elements and the oven have their own controls so odds are that the problem is with the house wiring.
Looks like L2 side of the line is out as L1 to Neutral (120 volts) powers the control board but the elements reqire L1 to L2 (240 volts).
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
